Twingo C06, BJ:98, OBD auslesen
#46
With the D4F an D7F open circuit is -40 degrees.
Short circiuit should be something above 120 degrees or so, I didn't test this.
All the old CLIPs that you can buy are clones.
I don't know whether there are good ones.
Usually, if they work, they work fine.
I don't think so. The less resistance the higher the temperature. I checked the manual.
(02.03.2020, 01:20)Broadcasttechniker schrieb: This one should work.
Please show us some screenshots.
I made a video:
https://www.youtube.com/watch?v=12NAm7e6TtA
I think I'm going to sell it on ebay and buy a better clone.
So it works, that's o.K.
What more do you expect?
Whatever it is, you won't get it.
There is no better version.
You should install a screen recoder.
With this you hands are free and there is no shaking.
To connect, the ignition has to be on and stay on exept für 2 seconds if you want to stop the motor.
Es bedanken sich: ronenfe
#50
(02.03.2020, 10:03)ronenfe schrieb: I don't think so. The less resistance the higher the temperature. I checked the manual.
It was indeed a bad engine coolant temperature, after replacing it with new, car starts great.
  Fehlerspeicher auslesen mit ddt4all milano 3 469 26.07.2026, 09:44
  OBD2 Auslesen - Geräte und/oder App Empfehlungen? domatrix 12 11.300 08.12.2024, 15:00
Letzter Beitrag: Rennsemmel1
ZZTwingo1 OBD2 Daten auslesen MasterOfDesaster 3 5.759 05.05.2018, 22:46
Letzter Beitrag: MasterOfDesaster
  Phase 1 mit Airbag und Gurtstraffer mit Clip auslesen? Patchworker 2 5.360 14.03.2016, 16:23
Letzter Beitrag: Patchworker
ZZTwingo1 ABS Fehler auslesen was mache ich falsch Silver8787 6 10.434 08.02.2013, 00:38
Letzter Beitrag: mkay1985
  WFS-Transponder auslesen Harald_K 5 17.431 07.04.2012, 08:59
  Programm zun Fehlerspeicher auslesen ?? hämmer 11 22.790 30.06.2011, 15:10
Letzter Beitrag: haemmer
  OBD am Twingo auslesen - Projekt CarPC Tobi -TFNRW- 6 12.861 12.02.2009, 19:25
