Glasdach motor / Schiebedach motor / sunroof motor HELP!!
Hello to everyone!
first of all, sorry because I am writing in English, but I don't speak German, and on this forum I found more information
that anywhere else on the web.
I have a problem with my sunroof motor (Glasdach motor, Schiebedach motor) for my Twingo 1 (year 2001). It seams that it has to be replaced. Does anybody
know where I can find it? Does anybody have it and would like to sell it? I am interested to by the entire plastic mask with
switches for the motor!
I tried to search on this forum, but, as I told, I don't understand German, so it is a problem for me.
Thank you so much, i will appreciate any help!!
all bests
Superdeka
You mean this right ?
Real Drive is R Drive
(11.07.2012, 14:38)Kos schrieb: You mean this right ?
Thank you Kos!
I mean that one! I have already found this one on the ebay, but actually I don't know if it fits to the twingo model from 2001, like mine. Do you know I it will fit correctly in that on.
I am asking because there is written that it is the model from 1999.
Thank you so much
superdeka
there was only one enigne in my mind.
should fit.
(11.07.2012, 15:17)Kos schrieb: there was only one enigne in my mind.
should fit.
Ok, thank you very much, Kos!
as stated here in this community, the prob with te motor of the sunroof is in many cases a worn sprocket between the motor/gear-unit and the roof itself (the roof doesnt move an you her a rat-tat-tat from the mechanics) .. in those cases it might help if you mount some washers between the motor/gear-unit and its fixing points, so another segment of the worn sprocket will be used for transmission and you might save the money for the new motor.
maybee you look at this thread:
http://www.twingotuningforum.de/thread-13645.html
there are some thumbnail pictures at several postings, just click them to enlarge ....
ZZTwingo1 Motor springt nicht mehr an. Anlasser dreht, Benzinpumpe und anderes tot.[GELÖST] Robert79 34 6.118 20.06.2026, 16:38
Letzter Beitrag: TwinGoVegan
ZZTwingo1 Zündung an/keine Kontrolleuchten/Anlasser dreht/Motor springt nicht an Barnix 19 5.934 03.06.2026, 06:46
Letzter Beitrag: Barnix
  Twingo 1, Motor startet nicht, Batterie hat 12,6V germeier 3 1.504 06.01.2026, 09:48
  Leuchtweitenregulierung Motor einbauen Plattenputzer 8 2.636 23.08.2025, 10:18
Letzter Beitrag: Plattenputzer
  Motor reagiert nur unzuverlässig (mal geht er an mal reagiert er garnicht) Tomtomtom647 8 2.474 26.01.2025, 13:39
ZZTwingo1 motor springt schlecht an. terorkruemel 4 3.468 26.09.2023, 12:23
Letzter Beitrag: terorkruemel
  Leuchtweitenregulierung Motor ausbauen BlackScorp 10 22.601 07.12.2022, 09:26
Letzter Beitrag: V320001
  brauche hilfe Motor springt nicht an heingumpel 2 3.998 15.08.2022, 17:32
Letzter Beitrag: heingumpel
