d4f and d4ft camshaft specifications
Du kennst mein Denglisch noch nicht , das ist funny ! Laughing
i am used to driving laggy engines, big turbos on the old C1J, i don't mind sacrificing 1000 rpm low down for 1000 rpm more revs and more power. I do have a spare turbocharger i was thinking of getting bigger turbine and compressors fitted into, a bigger 2.5inch exhaust would probably help also. I am only really tuning this engine for fun and to prove a point as no one in the UK thinks much of them in favour of the F4r and the F4rt.
If the engine dies its not too much of an issue as they are cheap over here in the uk and plentiful
OK , please send me one D4Ft for my Twingo 1 . Very Happy
https://rover.ebay.com/rover/0/0/0?mpre=...2806681003
Sorry , only a Joke , for me is only a Ford Cosworth 24V V6 a option to change the Engine in my Twingo . Cool
off topic but why! what a horrendous engine
Why not , i had a very good Time (6 Years) with the Engine (BOA) Scorpio MK1 .
(29.09.2019, 20:28)Adeyspec schrieb: off topic but why! what a horrendous engine
....finally someone who knows it....Laughing
Oliver
Das sagt der Richtige ! Very Happy
Der Motorblock ist Made in Germany (Köln V6) , deutsche Qualität von Cosworth veredelt . Cool
Older Versions from D4F
Lift :
Inlet - 8,849 mm
Outlet - 8,850 mm
do you have an engine number or an idea of what car this camshaft came in? i have found a company that can regrind it to reduce the base circle diameter
This Info i have from Twingo Doku .
But i'm not sure how good this Info .
Normal from D4F 702 to 728 .
But it comes a Change by D4F A 702 to D4F B 702 ,
The Zylinder Head changed .
One Tuner have a Camshaft , but he give only for Engine D4F B 7...
Not for D4F A 702 !!!
D4F B 702 , 712 , 714 have new Zylinderhead , but with trottle inside .
D4F 708 , 722 , 728 Trottle on Side .
Twingo Doku say old Camshaft for Lift and Timing , at 740 new camshaft .
Old Cam is higher .
@Adeyspec
Perhaps you try to contact Weber83, he had a 290° camshaft in his D4Ft, that was also regrinded.
https://www.twingotuningforum.de/thread-17170.html
https://www.twingotuningforum.de/thread-...pid8549882
Oliver
Es bedanken sich: Adeyspec
#28
Hier geht es aber um ein Alltagsauto , der Twingo von Weber war ein reines Spaßauto mit viel E85 !
Bevor ich mir im Alltag beim 16V eine 290° Nocke antun würde , dann doch lieber die umgeschliffene 260° von Dbilas .
https://dbilas-shop.com/motor-ventiltrie...fen?c=8728
#29
Was ich damit sagen will, er soll sich mal mit jemanden in Verbindung setzen, der Ahnung vom Tuning eines D4Ft Motors hat und nicht mit jemanden der glaubt, die Luftmasse durch Löcher im Luftfiltergehäuse einstellen zu können...
Außerdem glaube ich nicht, dass es um ein reines Alltagsauto geht, wenn ich diesen Thread lese: https://www.twingotuningforum.de/thread-40493.html
Oliver
(02.10.2019, 09:19)Oliver schrieb: @Adeyspec
excellent threads for me to try and read, thanks for the point in the right direction
ZZTwingo1 Motorumbau D7F > D4FT C06Toujours 16 9.861 20.03.2026, 04:54
Letzter Beitrag: C06Toujours
ZZTwingo1 D4ft D4f 780 Unterschiede Stanley1205 2 879 10.03.2026, 22:20
Letzter Beitrag: Stanley1205
ZZTwingo1 Gibt es D4FT Unterschiede? C06Erik 3 3.065 02.04.2025, 09:32
ZZTwingo1 D4FT im C06 Fatum 18 22.179 25.04.2021, 09:58
  maximum torque D4FT Adeyspec 7 9.876 25.03.2019, 07:40
