05.10.2021, 21:53
Hello Mister
I have an Express C3G.
I try to read the ECU data to make sure that all devices are OK : the rate of CO is no good
I have tried to do the same as you did : XR25 on PC+ODBII with 4 cable to the odb 12 pins : ground, +12V, K line, L line.
It didn't work.
Are you sure your car is a C3G, because C3G is supposed (as far as I read) to connect with ELM (ISO 9141), not with ODBII.
Thank you for any explanations
It didn't work.
