Themen: 10
Bedankte sich: 42
680x gedankt in 576 Beiträgen
Water can cause a short circuit under the fuse box!
Did you clean the holes from the stress bolts ?
They could be filled with water or something like that...
And this procedure done :
Oil bolts, 20 Nm, 90 degrees, loosen, and same again ??
Would agree, there is a leakage between cylinder liners and gasket.
Themen: 31
Bedankte sich: 28
33x gedankt in 28 Beiträgen
Thanks. Yes. I did tightened it exactly like that.
Themen: 10
Bedankte sich: 42
Did you open the bleeding screw on the thick tube near the water pump ?
Knead this tube when filling up the coolant till it rinse out . This is very effective by the way.
Other thing is, Renault fixes the cylinder liners with special tools,
the gasket must not be removed once installed ! Die hard project.
Themen: 31
Bedankte sich: 28
Yes. Did it from the bleed screws before I started the engine.
Themen: 10
Bedankte sich: 42
Thermostat opens so the cooler heats up ?
I think you are done with it .
Themen: 31
Bedankte sich: 28
Yes. Hose starts to get hot after a while.
Themen: 229
Bedankte sich: 7595
8331x gedankt in 6764 Beiträgen
19.09.2018, 21:49
(Dieser Beitrag wurde zuletzt bearbeitet: 19.09.2018, 21:50 von Broadcasttechniker.)
Did you replace all 4 cylinderfoot gaskets?
You have to do that when the cylinders were mooved inadvertently.
I once had to do that in my sisters R4.
Themen: 31
Bedankte sich: 28
Unfortunately not. Do I have to remove the oil pan now? Can it be done without removing the engine? Any tutorial?
Themen: 229
Bedankte sich: 7595
20.09.2018, 07:19
(Dieser Beitrag wurde zuletzt bearbeitet: 20.09.2018, 07:34 von Broadcasttechniker.)
Yes you have to.
But, please check first what happened to the O-rings. Page 57 of 103 MR-C manual.
The engine of the R4 had the Excelnyl gaskets an I choose the thickest one without measuring.
With the O-rings you should not have a problem, exept when the O-ring has split and now sits between cylinder and motor housing.
Please also read and check what is written obout the cylinder protusion.
You have to open all big ends. Make shure you don't mix the parts up.
A pain in the ass. With the R4 you had to remove a stabilizing bar (not the stabilzer) between the longitudinal chassis beams.
But I think with the C3g thats easier.
I don't know whether we mentioned this page before
http://www.mbarak.de/twingo/rep-insp/ZKD/ZKD.htm
Do a Google translation.
Themen: 229
Bedankte sich: 7595
20.09.2018, 10:15
(Dieser Beitrag wurde zuletzt bearbeitet: 20.09.2018, 10:16 von Broadcasttechniker.)
You only have to remove the big ends of the cylinders in question.
In my case I had to remove them all because i didn't know how thin or thick the old gaskets were.
Besides.
If there is no water in the oilsump, the O-rings will be o.K.
So dont do anything that is unnecessary
With the R4 of my sister there were no compression problems but water in the oil.
Themen: 229
Bedankte sich: 7595
You can do that, but that won't remove a broken O-ring nor would that replace ist with a new one.
I agree with you if you do not want to remove the oil pan without a reason.
Check why it is not possible to push the liners right down to the block.
Is the feeling springy or solid when you try to do that?
