C3G engine head removal - Twingo 95
#31
You mean the pipe clamp ? Always hand-tighten .
Plugs 30 Nm.
Ignition should be on for 60 seconds before cranking. Good luck.
(27.06.2018, 09:25)ronenfe schrieb: [Bild: 2018-010.png]
I mean number 5 nuts.
What do you mean pipe clamps should be hand tighten only? I used tools for everything.
You mean cranking so the engine gets fuel and then connect the ignition?
I mean oil, not fuel.
Number 5 has no torque, you turn till the end of the winding,
so the nut is about 1 cm on it.
Follow your instincts, there is nothing difficult about it.
Ignition on because of starting problems and internal throttle calibration.
So what do you mean crank the engine for 60 seconds before starting? Remove the spark plug wires.
You were right, it says 18nm but maybe it's a mistake.
Angehängte Dateien
.pdf   t.pdf (Größe: 1,3 MB / Downloads: 8)
I meant to attach this:
So it could be expansion bolts, a print error or 12.9er bolts.
Its not that important.
What about your car, any problems yet ?
I still have to put back the distributor, accessory belt and exhaust pipe.
Man, putting back the spring and nut for the exhaust pipe was one of the hardest things I have ever done, I needed to use a magnet stick to get the nut to the bolt.
(11.06.2018, 07:29)Broadcasttechniker schrieb: The distributor doesn't have to be fineadjusted because the timing doesn't depend on its position.
So I would remove it.
Does the orientation of the shaft notch matters when I put it back? because It can be put in 180 degrees difference, can't it?
I put everything back, I have sparks, the injector seems to work, but the car doesn't start. What should I do?
Rearrange the ignition cables
[Bild: twingo-09272151227-Sz.jpg]
And check the distributor cover and finger
This is the arrangement I have, and I have spark on each wire, do I still need to check the distributor cover? I tried to rotate the finger 180 degrees, but it only goes in all the way only in one position so this is not the issue, what else can I test? do you know the compression values for this model?
New distributor arm new distributor ?
Check all connections , control device, ground cable, Map-Sensor, Lambda .....
Compression is 11 bar. Valve clearance checked, outlet 0,2 mm, inlet 0,15 mm?
Firing order is 1-3-4-2.
Switch on ignition, then wait 60 seconds before starting.
Another way is to push gas pedal down for a very short time while cranking the engine.
Always check for wet plugs. Tubes all clean and connected,
Map sensor tube also very important.
  D7F engine ticking noise. mehmetcihat 1 2.939 08.07.2022, 12:22
Letzter Beitrag: Opti1711
  Different sound of engine - D4F 16V sasio 2 6.341 23.09.2012, 20:41
Letzter Beitrag: sasio
  Engine Check problem Sangheili 4 7.618 23.01.2012, 20:27
Letzter Beitrag: Sangheili
