Its been a while since ive posted, ive been home due to the pandemic since march 2020 bar a little bit of part time work before chirstmas which has given me lots of time to work on my other car, 1957 Renault Dauphine, i built a 1108cc engine for it and fitted it in with a 4 speed box. Next up has been the Twingo, i wanted more power......... the little engine wasnt enough. So ive started to build a conversion using all renault parts.
Megane r26 engine, block drilled for 5 speed
172 sump, 172 flywheel, twingo rs133 clutch cover, duel friction plate, megane 5 speed dci jr5 gearbox so i retain the the hydro clutch and cable shift, GT passenger side driveshaft, hybrid right hand side shaft, inner Clio 3 DCI outer half is 172. Miltek 3 inch downpipe. Walbro 255ltr fuel pump and 4bar FPR. GT throttle body and modified GT wiring loom to suit the engine.
All runs on the GT ecu which will be remapped to suit the new engine
https://www.youtube.com/watch?v=3zdvUenfRfU&t=29s
Hope to get it finished in the next 2 months so i can take it for mapping on the dyno, I want 250bhp from it so not really pushing the engine but should be quite quick
