Different sound of engine - D4F 16V
Hi.
I've got a problem with my engine in my Twini.
Well, sound from engine is a problem.
When I push a pedal of gas I hear "tsst" sound from engine.
This sound looks that turbo, and is only 1 second sound.
Every push a pedal = this same sounds.
I try solve this problem but without result.
I removed a cover of AirFilter, remove Filter and insert hand "in engine", and when my friend push pedal I feel a hit of air, not suck air but push air (inversely than normal)
My friends (about 10 person) also have this same problems with own 16V
The moment the trottle opens there is a fizzing sound just as you described it.
But it should be shorter than a second. It is definitively longer and louder than with a mechanical throttle because the opening speed is limited by hardware and by software.
The other observation you made isn't that easy to interpret, but i know that it is difficult to determine the direction of airflow when it is not very strong. For example i can't determine the direction of the airflow of a fan. I can feel it, but i can't tell the direction. I help myself and take a piece of paper looking for the deflection.
Hi.
Today I remove a lot of things in engine, and show the throttle...
[Bild: 246676_443746225675788_1449237868_n.jpg]
Well, the throttle was very dirty, in old oil, and after the clean, I check a crankshaft breather pipe, but is in good healthy...
I cleaned all of dirty things, seal all of parts.... but this sound is still there... not louder, not quitly, this same tsst.
I talked about this problem with a lot of person which have got a D4F in Clio and Twingo, and also hear this same sound, but not everyone...
Some idea?
  D7F engine ticking noise. mehmetcihat 1 1.738 08.07.2022, 12:22
Letzter Beitrag: Opti1711
ZZTwingo1 C3G engine head removal - Twingo 95 ronenfe 152 82.701 04.09.2020, 01:05
Letzter Beitrag: ronenfe
  Auspuff mit Absorber Sound Thomas_Reiter 14 8.981 05.07.2017, 14:44
Letzter Beitrag: Thomas_Reiter
  auspuff sound wegfahren Thomas_Reiter 7 5.081 05.03.2017, 10:14
Letzter Beitrag: Urlauber51
  Engine Check problem Sangheili 4 5.457 23.01.2012, 20:27
Letzter Beitrag: Sangheili
