  • 1 Bewertung(en) - 3 im Durchschnitt
Gordini #159
Hallo aus Schottland.
Ich bin ein Moderator auf einer britischen Twingo Forum: - www.twingo133.net
Hier ist meine RS Gordini.
[Bild: 6288696238_b0e4af0a8e_b_d.jpg]
Mehr von meinen Fortschritten können Sie hier sehen>>
http:// http://www.twingo133.net/twingo-...t1816.html
i like your twingo Wink
Looks Cool Smile
Like the Rallye look Smile
Hi singlespeed,
its a pleasure to have you here.
I havent registered myself on the 133 forum till now yet I allready know you and your rs133! As far as I remember you're the one with the full supersprint system? Cause I did read your review about it.
Just a small question bout' the supersprint: Did you experience the same flatspot at 2k rpm with the full catback system as I did or not?
Enjoy your stay here and I hope you have no problems with understanding all the german written messages here. I heard google translater works better and better Very Happy
Hey singlespeed,
i like your twingo! It looks very niceWink
Gruß,
Peter
(17.01.2012, 20:54)Rotfuchs schrieb: Hi singlespeed,
[Bild: 5984159864_b8f3e8c39f_b_d.jpg]
Ein Bild sagt mehr als tausend Worte. 95RON Sad
Leider ist mein Deutsch ist schlecht wird seit 30 Jahren ungeübte. Hoffentlich Google übersetzen Werke grom Englischen ins Deutsche Very Happy
thanks for the dyno sheet!
theres no flatspot like I have as far as I see.
I think of some leakages between catalytic converter and downpipe which can cause mismeasurements of the oxy sensor...
Hi singlespeed,
nice dyno sheet, do you change the limiter for the rpm?
when i see it right, your max rpm is 7200-7300rpm?
kind regards
Pi
better you write in english, google translate ist quite bad Wink
nice car!
mein Horst
Spritmonitor
(19.01.2012, 08:56)Jenss schrieb: better you write in english, google translate ist quite bad Wink
Ok, sorry Sad
A new air intake box
Take one Clio 197 Ph1 filter housing
[Bild: 6870069749_2fb69d2d88_z_d.jpg]
chop the middle out of it, leaving just the base and a top ring to clip onto the top of the intake
[Bild: 6964639745_7f2b162225_z_d.jpg]
Make up a carbon tube and then wrap the can in a couple of layers of carbon. Make a duct to fill the large gap above the radiator, where the original scoop was... Cut a large hole in the new can and join the two parts together.
BMC filter element installed
[Bild: 6812609648_ccbb873896_z_d.jpg]
[Bild: 6812612508_1c5c2f98fd_z_d.jpg]
[Bild: 6958724803_148f6b3cff_z_d.jpg]
[Bild: 6812617052_f4df0637b5_z_d.jpg]
Theres about 1mm either side, between the lid and the battery, lid and cable connector
[Bild: 6812619204_8ac90680ca_z_d.jpg]
[Bild: 6958731023_3467accbd3_z_d.jpg]
It's just a little bit bigger than the 70/130 CDA Confused
[Bild: 6958733309_f363f66bb1_z_d.jpg]
