Is it easy to replace the seal of the gear selector?
I noticed the dust cover is dry and the seal may leak a little.
I have seen here a post regarding it recently but I can't find it.
How can I replace the seal. Do I need to drain the transmission oil first?
Also what is the purpose of the sensor to the right? It may leak too.
[Bild: twingo-12193629-a4R.jpg]
Please, just absolutely forget about ist.
Your gearbox is fine.
There a plenty of threads in this forum, just do a google search.
I'll do it for you
https://www.google.de/search?hl=de&biw=1...CAY&uact=5
Don't try any of the solutions, just leave it like ist is.
As long as there's still some greenery growing under your car, you're fine Smile
The sensor is leaky ,malfunctioning with reverse gear indicator in the right backlight is possible.
  Is it even possible to replace a cv boot on this type of shaft? ronenfe 17 4.736 08.07.2020, 18:07
Letzter Beitrag: ronenfe
ZZTwingo1 Anyone has this plastic part 7700743133 for his gear link? ronenfe 3 3.597 22.03.2020, 23:42
  Steel Seal für Zylinderkopfdichtung Trinacrius 1 9.603 02.08.2014, 08:05
Letzter Beitrag: ogniwT
  Twingo 95 easy gino95 2 3.026 18.12.2013, 20:28
  Twingo 95 easy e10 gino95 2 4.024 21.11.2013, 23:54
  Twingo Easy Umbau auf Schaltung Mike B. 2 3.625 15.11.2013, 16:18
Letzter Beitrag: Mike B.
ZZTwingo1 twingo easy 1995 schaltung ok? Johnny0815 18 17.976 06.07.2013, 21:12
Letzter Beitrag: Johnny0815
  P0702 bei meinem C06 C Easy norben 0 2.349 31.05.2012, 00:49
Letzter Beitrag: norben
