C3G engine head removal - Twingo 95 - Druckversion +- Das Twingoforum... (https://www.twingotuningforum.de) +-- Forum: Werkstatt (https://www.twingotuningforum.de/forum-31.html) +--- Forum: Motor (https://www.twingotuningforum.de/forum-55.html) +--- Thema: C3G engine head removal - Twingo 95 (/thread-39470.html) |
RE: C3G engine head removal - Twingo 95 - ronenfe - 25.04.2019 After 1000 km I checked compression again and it improved. Before I had: 1. 125psi 2. 80psi 3. 90psi 4. 140psi And now: 1. 150psi 2. 110psi 3. 110psi 4. 175psi About 20 percent increase. I'm going to re-check valve clearance now. RE: C3G engine head removal - Twingo 95 - ronenfe - 29.04.2019 After valve adjusment: 1. 155psi 2. 112.5psi 3. 117.5psi 4. 185psi RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 29.04.2019 You can't enhance the compression by adjusting the valve clearence unless ist was completely wrong (to tight) in the beginning. Just drive the car and see what happens. RE: C3G engine head removal - Twingo 95 - ronenfe - 14.05.2019 Yes, car runs great except during the first few minutes when engine is cold. I need to let it warm up a few minutes on idle, Or else the engine chalks. I am going to check the ecu for problems with xr25pc when the cables I had ordered arrive. RE: C3G engine head removal - Twingo 95 - ronenfe - 25.03.2020 It was the engine coolant temperature sensor. I replaced it and it fixed the problem. RE: C3G engine head removal - Twingo 95 - ronenfe - 27.04.2020 (24.09.2018, 23:14)Broadcasttechniker schrieb: No Problem. You are right, those guys did it like this: https://youtu.be/AnHdAcM6c4w?t=1122 RE: C3G engine head removal - Twingo 95 - cooldriver - 28.04.2020 Very bad pressure values. Cylinder 2 and 3. Probably, something went wrong with your overhauling. RE: C3G engine head removal - Twingo 95 - ronenfe - 28.04.2020 (28.04.2020, 15:06)cooldriver schrieb: Very bad pressure values. Actually the car runs great. Maybe the valves don't seal properly or the head is distorted too much but it works as before if not even better. I don't feel any problem. RE: C3G engine head removal - Twingo 95 - cooldriver - 28.04.2020 Interesting, so what about acceleration and maximum speed ?? RE: C3G engine head removal - Twingo 95 - ronenfe - 01.05.2020 It's great, I can get to 150kmh, 160kmh, accelaration I haven't measured but looks good. RE: C3G engine head removal - Twingo 95 - rapiderich - 01.05.2020 (27.04.2020, 23:17)ronenfe schrieb: https://youtu.be/AnHdAcM6c4w?t=1122 geile schrauber, großartiger motorschaden (die pleuel....), läuft! gruß, stefan RE: C3G engine head removal - Twingo 95 - ronenfe - 02.05.2020 Well, I measured 15 seconds acceleration from 0 -100 km/h. Specs says 14 seconds And top speed 150 km/h so it runs according to specs, I'm surprised. I do have jerkings when I move from full opened throttle on high speeds to a closed throttle , I have to do it gradually. RE: C3G engine head removal - Twingo 95 - cooldriver - 02.05.2020 And fuel consumption is under 3 l/100km, i know. RE: C3G engine head removal - Twingo 95 - ronenfe - 23.05.2020 13.4 km/l RE: C3G engine head removal - Twingo 95 - ronenfe - 20.08.2020 So unfortunately I have to remove the oil sump again because I got a little leak on the right side. I'm going to put a lot of sealant now. I wanted to tell I found out how to remove the air conditioning compressor without opening the lines. There are metal pipes which are not flexible. That's why I couldn't move it. I found out there is a hidden bracket that holds them in place behind the front subframe. Removing one screw there allows flexibility. If anyone can give me advice how to put the sealant I will appreciate it. The manual says not to put sealant in some places but I want to put it everywhere also under the 2 half moon rubbers , is that ok? |
