Informationen über sjk7644 |
04.09.2018 |
Letzter Besuch: |
04.09.2018, 09:13 |
Beiträge (gesamt): |
0 (0 Beiträge pro Tag | 0 Prozent aller Beiträge) |
Themen (gesamt): |
0 (0 Themen pro Tag | 0 Prozent aller Themen) |
Gesamte Onlinezeit: |
2 Minuten, 3 Sekunden |
Empfohlene Benutzer: |
0 |
Zusätzliche Informationen über sjk7644 |
Geschlecht: |
weiblich |
Twingo Baujahr: |
2003 |
Dein Motorcode: |
D7F > 1149cm³ 8V Benzin |
SS |
Biografie: |
12V / 24V 18 Watt Cree Round LED Truck Mounted Work Lights with 3 Years Warranty
Specification:
1.model number?E-WL-LED-0007
2.HIGH POWER LED:6 X 3W
3.LAMP Dimension:128mm x 116mm x 40mm
4.Voltage:10V-30V
5.Luminous Flux: 1380Lm
6.Working Temperature:-45 ~60°C
7.Service Life:?30000Hours
8.Color Temp :5000~6500K
9.Waterproof: IP6K9K
10.Material:Aluminium magnesium alloy
11.Guarantee: 3 years
18w square led cree work lights advantages and characteristics
1.led truck work lights using high grade PC with heavy-duty die cast aluminum alloy housing.
2.High performance work light, IP 6K9K waterproof rate allows it to have excellent dust-proof, rust-proof, and anti-corrosion performance, works well even in extreme conditions.
3.Widely applies for various indoor and outdoor uses, our work light is easy to be installed and mounted, it can be used on all automobiles and devices equipped with a 10-30 volt DC power source.
Applications:
Truck, bus, off road vehicle, atvs, boat, engineering vehicles(excavator, treedozer, road roller, bulldozer, crane and mining truck etc.), special vehicle(fire engine, police cars, rescue vehicle, communication vehicle, military command vehicle), forklift, trains, tanks, mining and marine.
why buy 18w square led cree work lights from Ether:
1. Usually our trader manager is online, you can ask questions by trader manager anytime. If nobody online, you can send us an inquiry, we will reply you within 12hours.
2. We are factory supplier ,We can devolope a new products as customer request.
3. Quality oriented , Price continuously cutting down .On time delivery
4. We have long-term cooperation with our forwarder, so we can provide you the lowest freight cost and the fastest service.
FAQ:
Q: Where do you source your led truck work lights LEDs from?
A: Intact imported from United States.
Q: What is your led truck work lights sample policy?
A: We can supply the sample if we have ready parts in stock, but the customers have to pay the sample cost and the courier cost.
Q: What’s the led truck work lights spot beam, flood beam?
A: Spot beam led truck work lights is long-range.Flood beam led truck work lights light is wide-range.
Q: How long will it take to execute my order?
A: This depends on the order quantity.our normal delivery time is 3-5working days.
Q: What are the main products of your company?
A: Our company is mainly led work light,led headlight,led fog light , led tail light, led light bar
Q: What’s the Failure of the led truck work lights?
A: Less than 0.1%-0.3%
Q: Are there any testing be done before shipment?
A: Each light have passed the resist shock testing, electrostatic protection testing 2 times waterproof testing and 3 hours aging testing.China Round Led Work Lights suppliers
website:http://www.autoworklight.com/led-work-lights/round-led-work-lights/ |
