Antwort schreiben
What's the purpose of this connector?
Verfasser Nachricht
ronenfe Offline
Member
Bewertung 0
Bedankte sich: 8
6x gedankt in 5 Beiträgen
Beitrag #1
Is it for the Easy system? Why does it need so many wires?
[Bild: twingo-11012211-him.jpg]
11.07.2019 00:22
Broadcasttechniker Offline
Ulli mit 2 "L"
Bewertung 117
Bedankte sich: 4339
4510x gedankt in 3701 Beiträgen
Beitrag #2
RE: What's the purpose of this connector?
If your Twingo was an "Easy" model, this could be the connector for the respective ECU.
Many if not all "Easy"s were convertet to ordinary clutch.
The shift stick should have a contact in this case, look for it.
11.07.2019 07:27
ronenfe Offline
Member
Bewertung 0
Bedankte sich: 8
Beitrag #3
Yes my twingo is an easy converted to manual. But I don't understand. Did it have a computer inside the car to manage it? Besides the ECU outside? I wanted to remove the connector at the beginning because I thought it's for an aftermarket alarm system. But I understood its original. Also my car didn't start anymore after I removed the connector's ground. Took me a whilr to realize it's the reason.
11.07.2019 08:23
Ulli mit 2 "L"
Bewertung 117
Bedankte sich: 4339
Beitrag #4
Yes, exactly, the easymatic omputer was inside.
You can bridge the starter-inhibitor relais if you want.
The relais prevented the motor from starting if a gear was engaged an the clutch wasn't disconnected.
The gearbox has a relatively complicated switch in the place where a "normal" Twingo only has the reverse light switch.
http://www.twingotuningforum.de/ruckfahr...16101.html
11.07.2019 09:07
Antwort schreiben
