C3G engine head removal - Twingo 95 - Druckversion +- Das Twingoforum... (https://www.twingotuningforum.de) +-- Forum: Werkstatt (https://www.twingotuningforum.de/forum-31.html) +--- Forum: Motor (https://www.twingotuningforum.de/forum-55.html) +--- Thema: C3G engine head removal - Twingo 95 (/thread-39470.html) |
RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 23.09.2018 That ist the problem. Remove, yes. But why disconnect? Look at my pictures. Why do you always have to learn the hard way? RE: C3G engine head removal - Twingo 95 - ronenfe - 23.09.2018 Your pictures don't look like the same compressor. The two gas lines are not flexible and limit the movement of the compressor. I needed to rotate the compressor in order to get space for the sump to get out. RE: C3G engine head removal - Twingo 95 - ronenfe - 24.09.2018 Removed all liners. What a mess. I shouldn't have used a head gasket repair fluid. O rings were all bad. I'm going to clean everything. RE: C3G engine head removal - Twingo 95 - ronenfe - 24.09.2018 This is the compressor of the twingo, there are different kinds. RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 24.09.2018 No Problem. Remove the screws and pull it downwards. Never mind the rigid lines, at the other end they are flexible. RE: C3G engine head removal - Twingo 95 - ronenfe - 24.09.2018 I tried. It didn't go down enough. Maybe I had to use more force. RE: C3G engine head removal - Twingo 95 - ronenfe - 27.10.2018 I bought this oil pan gasket: http://ows-cdn.tecdoc.net/ajusa/home.jsp?server=7&time=27/10/2018-21:31:11#7622b0c6015695e968530ef097891e7e Do you think I can Use it instead of putting a sealant, I had a white kind of flexible sealant when I removed the pan. This one is made of cork. I mean Ajusa 59001500 RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 27.10.2018 I think that you can use it. I would apply Hylomar additionally, and if it was only to fix the seals slightly so that they don't move when you mount the pan. RE: C3G engine head removal - Twingo 95 - ronenfe - 27.10.2018 Thanks, can anyone explain me those goetze unclear piston rings instruction drawings? RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 27.10.2018 1. Correct assembly of the oil ring(s), especially the orientation of the gaps. 2a. Correct orientation of the oil scraper ring especially up/down orientation, very important. 2b. Do NOT overstretch the rings while mounting them. This is not so easy because they loose their circular shape when you expand them. Hence the special pliers. But you can do without them, just be very carefull. 3. Check vertical gap of the compression ring. If you ask me, that only makes sense if you reuse the piston. RE: C3G engine head removal - Twingo 95 - ronenfe - 28.10.2018 1. so what is the correct assembly? what do a, b, c drawings mean? They are all the same drawings but a has a yellow paint in it. What do the top, middle and bottom rings ressemble? And what do we see on the right? The oil ring upper part and bottom part are actually connected together like this: 2a. I don't understand what all those 4 columns mean. The rings are marked with a top sign, so I don't understand the need for the orientation diagram. The scrapper ring doesn't have a gap, it's one unit with a spring. like that: http://www.federalmogul.com/en-US/OE/Brands/Goetze/Pages/Product-Details.aspx?BrandId=40&ProductId=704 2b. this I understood. 3. This I also understand that I should use a feeler gauge and it shouldn't reach more than half the groove. I think I got number 1, there are 2 different types, it's either the left side with 2 oil rings and an expansion ring with a gap, or the right side which I got, which is a complete unit. RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 28.10.2018 Yes, this is a universal scheme, so they show all kind of piston rings. RE: C3G engine head removal - Twingo 95 - ronenfe - 16.11.2018 I bought Glyco 01-4137/4 STD big end bearings for the c3g engine. They are wider than the originals and it feels a little step when I run my finger between the two halves. What do you think? https://www.fmmotorparts.co.uk/catalogue.html?fbclid=IwAR1Nyl5ujOMADq-vTf5Cx_O9-aXC6m4V3udJLkIS_t0UQTIyC1Tj9suMOkE#fitment_id=2132&search_type=vehicle&brand_id=2451 RE: C3G engine head removal - Twingo 95 - Broadcasttechniker - 16.11.2018 You can't just simply buy new bearings. Please read the manual very carefully about every single step. You have to measure the radial play with Plastigauge https://en.wikipedia.org/wiki/Plastigauge and the axial play with a feeler gauge. I don't know why you are doing all this stuff. Just reassemble the engine and you're done. RE: C3G engine head removal - Twingo 95 - ronenfe - 16.11.2018 Because they have scratches over them, and I thought it's better to have new ones if it's already opened. |
