C3G engine head removal - Twingo 95 - Druckversion +- Das Twingoforum... (https://www.twingotuningforum.de) +-- Forum: Werkstatt (https://www.twingotuningforum.de/forum-31.html) +--- Forum: Motor (https://www.twingotuningforum.de/forum-55.html) +--- Thema: C3G engine head removal - Twingo 95 (/thread-39470.html) |
RE: C3G engine head removal - Twingo 95 - ronenfe - 30.08.2020 That's the best way to move the engine mount aside to clear the way for easy reassembly of the oil pan. RE: C3G engine head removal - Twingo 95 - ronenfe - 01.09.2020 (29.04.2019, 00:08)ronenfe schrieb: After valve adjusment: Tested compression again and I get 175 psi or 12 bars in all cylinders, I have no idea how it became so good RE: C3G engine head removal - Twingo 95 - ronenfe - 04.09.2020 (02.04.2019, 18:01)ronenfe schrieb: I fixed it. It was the temp sensor connector for the ignition. It was torn before and I soldered it but the soldering broke. I resoldered it again and all works. I found a replacement connector after long searches, it's high quality and I won't have any problems anymore with this: https://www.aliexpress.com/item/32589330407.html?spm=a2g0s.9042311.0.0.f0214c4dAWQW2H |
