Themen: 224
Bedankte sich: 6721
7004x gedankt in 5790 Beiträgen
The most effective way ist to buy a Renault CAN CLIP Clone.
Costs about 120€.
It works.
If you have no money and lots and lots of time, search the web for DDT2000.
Themen: 27
Bedankte sich: 28
22x gedankt in 18 Beiträgen
My head gasket was repaired by a mechanic 1.5 years ago and now I have to do it again, I have air getting in the system. It blew on a hot day, but the overheat light never turned on. and Thermometer I installed showed 110 degrees max.
So no one could connect this 12/11 pin square connector to a USB?
Thanks for the link it will help me a lot.
Is there the same entire workshop manual in English? I only have a few files of it in English.
Themen: 8
Bedankte sich: 40
609x gedankt in 521 Beiträgen
I guess you are in a dead end.
You have to understand the entire manual ,
pdf file is named, mr_mot_c(e).pdf .
Its only french and german, for what i know.
Some notes: turn cylinder head before lifting, so the liners not moving.
You can fail easily. Vent clearance checked ?
Cooler warms up ? CO test positive?
Temperature warning is at 114 degrees, so i remember.
OBD is insufficent att all , its only possible to read out some sensors.
Themen: 8
Bedankte sich: 40
New nuts should have the Renault dealer.
To remove the ignition distributor could be challenging.
(move cylinder 1 in tdc position at first ).
Please share your experiences.
Themen: 27
Bedankte sich: 28
Do you know of a good online store for buying Renault parts?
Can't I leave the distributor attached. It doesn't look like it's blocking the head.
Themen: 224
Bedankte sich: 6721
The distributor doesn't have to be fineadjusted because the timing doesn't depend on its position.
So I would remove it.
